Holding Mosaic pin in spine of blade?
What is a good way to hold a mosaic pin in the spine of a blade? I thought about epoxy like I use on scales, but thought there might be a better way.
Thanks in advance for any help.
Epoxy has worked fine for me. Piening the spine over the pins would look bad. Using a stone setting process like a jeweler might work, but the stock pushed over on the spine is still going to look bad. Just go with a good epoxy.
Gene
I would drill the hole out just a couple thou smaller and press it in.you could use epoxy to help slide itt in and add extra strength?
