- Jun 5, 2012
I'm trying to broaden my horizons, so to speak, and I was wondering how one determines the rate of distal taper to apply when hollow grinding along the spine, ala loveless.
As of right now, I've been doing all hollow grinds that follow the blade edge, which is fairly easy to do as long as you keep steady.
it's not quite as straightforward when hollow grinding along the spine, though, because if you get the distal taper wrong, you're either going to have uneven edge geometry, or uneven grind along the spine.
I was thinking that I could measure the drop from spine in several points along the tip portion, and then use that to form a ratio of reduction for the distal taper along those points? Is that a reasonable way to do it, or am I complicating things?
