I havnt been here in a few weeks been tinkerin. Ide like you all to help me out. I have only really done about 7 or 8 hollow ground knives and need to know a few more things as to what in the world im doing right or wrong. So I will explain the best I can what im doing and if my order of doing is wrong or could be improved please let me know. I just ruined my first knife and want to know where i went wrong . I also feel my finish may be wrong as well as to how i complete the knife after heat treat. First i profile with 60 grit then go to 100 grit to remove scratches then mark my steel with a black permanent ink marker just for guiding. I then go back to 60 grit and work down the steel till i have no more imperfections in the piece of steel . I then put my 10 inch contact wheel on and 60 grit orange blaze belt and start hollow grinding fee hand i file the ricaso by hand previous to sanding. I keep a close eye on my thick ness and then work each side as even as i can then move to 100 grit then 220 then 320 ,400 and then drill my pin holes. Before I ship I buff shinny . I feel if i do 90 % before heat treat then I only have 10 % when i get them back after heat treat and do 500 grit finish with the handle sanding and buffing. Very rare if I have to go back to less than 320 grit after heat treat . I would like to know after heat treat should i even put the 10 inch wheel on to sand with 500 on the hollow ground area as ive usually ground it to the limits and is almost sharp when i send for heat and can sharpen easily with the paper wheel system. I could hand sand the scale off from heat treat on the hollow ground area in a few min rather than risking over grinding. Am I being over cautious. I think my problem with grinding through the last blade was the new blaze orange belts are more agressive than the other semi ceramic belt i was using .I am now also using the structured abrasive belts for finishing up to 1200 grit. LASTLY should i use my digital calipers . I am going by feel and I now know i have to ease up when using the orange belts. thanks kellyw
