hi i was wondering if the handle and/or end cap of the buck 119 special is hollow or not. i am planning on drilling a hole in the handle so i can wrap it in para cord. does anyone have any suggestions?
. The flat tang of the blade extends through the phenolic handle and into the solid pommel.
True about the pommel and phenolic is the material the handle is made of. It is a plastic like material also used as an electric insulator.
thanks WH4F that clears some things up for me just gotta wait till my paracord gets here so i can figure out where i need to put the hole exaclty
Ok,,I'll ask... Why are you needing to put a hole in it to wrap paracord.
Unless you think it will prevent it from slipping around or you just need a starting point.
There should be a way to tie the cord without a hole. I have tied fishing rods before and could see the same method being used here. If you wanted to secure it, maybe a drop of epoxy at the terminal end to keep it from sliding.
Jump over on some of the other forums and ask about methods. There are bunches of cord wrapped knives without a starter hole.
Just curious....
yeah i want to keep the cord from sliding around by putting it all under tension between two points unless u have a better way of doing it
So army, let's get this straight.... Not a hole for a lanyard cord but to increase the grip in your paw? How about a 639 ? A discontinued knife but they are out there: what it is? The 639 is a 119 blade and a rubber handle molded on the tang. The blade can be had in plain 119 style, or the clip serrated, with or without a sawtoothed spine in green or black rubber. Clear? Do some searches for a Buck 639 or Buck Fieldmate and see what catches your fancy.
I do what I can....
Dave
the point of doing this mod is that i dont want to buy a new knife at the moment since that would cost alot more than some paracord from ebay
