- Sep 4, 2004
I can't see any advantage to doing it this way (relief after finished edge) and agree with Cliff that you risk damaging your finished edge.
Django606 said:So you're saying it is better to grind the relief angle BEFORE I sharpen at 40*, right?
Lavan said:Usually, I sharpen ...EACH.... crescent cutout separately even though the video show treating it like a plain edge.
The 40 degree first method allowed me to just do the motions like the video and still come out with scary sharp.
Dog of War said:I can't see any advantage to doing it this way ...
Django606 said:The toothier edge will still push cut and slice, right? How long do you use the gray stones after putting the final edge on it? I'm assuming you alternate sides every stroke, right?
Lavan said:I am assuming that I am not consistent on the final grind (after the recommended relief grind) and by doing it this backwards way, I am compensating for sloppiness by possibly ADDING a small portion of the edge at a steeper angle but only where the edge was uneven to begin with.
You'd make a great diplomat if you put your mind to it, Cliff ..... though I doubt it's in your nature, any more than it is in mineCliff Stamp said:Placebo effect is real and can be very strong.
bbcmat said:I'll cut the relief grind after true(ing) up the primary grind IF I need to remove a lot of material on nice symmetrically ground blade.
Dog of War said:You'd make a great diplomat...
Cliff, you seem to have an interest in accurate, fact-based perception of reality... (as i inappropriately and wrecklessly plunge into very deep water) I can't help but wonder where you are at politically...:foot:Cliff Stamp said:Yes, not with the traditional goal of such however.
-Cliff
Roosevelt was my kind of statesman ..... Teddy, that is. If I were Canadian, I think you might get my vote.Cliff Stamp said:Yes, not with the traditional goal of such however.Dog of War said:You'd make a great diplomat if you put your mind to it, Cliff ..... though I doubt it's in your nature, any more than it is in mine![]()
hara-kiri-yogi said:...you seem to have an interest in accurate, fact-based perception of reality...
