So I have been refining my design more and more for my first knife, and I had some mild steel to practice with. My 14" woodworking band saw with a bosch 3/8" metal blade cut through that 1/8" mild steel with ease. So I decided to go for it and cut my pattern out in the 440C I got from Jantz... my metal blade literally would NOT cut this stuff... It put a very minimal dimple in it and polished it where I was trying to cut. I finally gave up and cut off the section I was after using a hack saw, 2 bent blades later I got my 9" chunk cut off the bar. I then took it over to my 1x30 belt sander and the 120grit I had on there sucked at removing steel and just heated it up a lot. so I took it over to my delta bench grinder and that was even worse with my coarse wheel.
At the time my angle grinder was at a house I am rehabbing on the other side of town, so yesterday I made sure to grab that when I was there, today I will be getting some cutting wheels and using that. I also ordered some 3M 1x30 36Grit cubitron belts because I read good things about them on here.
Anyone know of blades for a 14" woodworking band saw that would work on 440C? or am I doomed to using an angle grinder for all of eternity?
Also I was looking at the belt sander for knife making at grizzly (http://www.grizzly.com/products/Knife-Belt-Sander-Buffer/G1015) and at that price tag I would be better off making my own with the spare 1725RPM electric motor I have sitting around in my shop, so I guess I need to find a good (cheap) supply of rollers then just weld up a frame for it all.
I figure if I make my own belt sander I will use 2 step pulleys so I can easily change the RPM, somehow spring load the roller with the pulley on it so that I can change sanding belts and rpm easily, and measure everything out about 50 times so that I can ensure a 2x72" belt will actually fit lol.
I guess the point of this thread is to say... I had no clue there was such a MASSIVE difference between the cheap steel at lowes, and the cheap steel at Jantz lol. Are angle grinders pretty much the standard for cutting out your rough blade shape?
