- Apr 3, 2011
Well, I never think about using it for final finish since I normally do a FFG on kitchen knives, and even hunter knives, so all the SGA finish would be in grinding the bevels. BUT - if a bevel was used that left the top part of blade flat then it could be final finish. Since I started using a disk grinder for final grinds, I'd use that for final flattening of any flats and cleaning up a good grind line.
Ahhh that makes more sense... I do a lot of bi-directional grinds like below (flats having grind lines parallel to the edge, grind being perpendicular) so it will make sense for me. But for your work not so much! That makes sense now.
This will definitely take some experimenting with the belts to get it dialed in just what I like. I am not opposed to spending $10-15/belt if it works better than the rest for what I need. I've finally got dialed in exactly what belts I like for all the other work (took several years) for my style of grinding (lower speed, low pressure, water cooled). A lot of ceramics don't necessarily fracture under these conditions but I've found the cubitron 984f's to work fine (36 and 120 grit) - but for my 60 grit belts I use Phoenix abrasives as one of their ceramics fractures nicely under lower pressure and I get decent life out of it.
