Home made stamp press
Can I make a good stamp press out of a hydraulic car jack? Anyone have plans for this?
Any other ideas for making a stamp press without spending big bucks?
Carl
HEY CARL, I'M FIXIN TO GIVE IT A TRY. I'M GONNA MAKE ONE THAT HAS THE JACK APPLYING GOOD SOLID PRESSURE FROM THE BOTTOM AND HAVE A STEEL ROD EXTENDING OUT THE TOP SO I CAN SMACK IT WITH A HAMMER. I FIGURE THE PRESSURE FROM THE JACK WILL HOLD THE STAMP STILL AND NOT LET THE IT JUMP ANY. I'LL SEND YOU THE PLANS IF IT WORKS GOOD. TAKE CARE! MICHAEL
"Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
I just built one. I used a 3 ton jack, although I think 5 ton would be better, frame of square tubing, a half in. plate for the jack to sit on, 4 short pieces of angle for guides and a couple springs to make the jack go back up, the jacks on top work on bottom. It works great.
MIKE, I THOUGHT OF PUTTING THE JACK ON TOP, BUT I WAS AFFRAID IT WOULD LEAK FLUID. DOES THE JACK ALONE HAVE ENOUGH PRESSURE TO STAMP ANNEALED STAINLESS?? TAKE CARE! MICHAEL
<img src=http://members.aol.com/l6steel/ebay/gunmn.jpg>
Michael, I, using the jack in the normal upright position. Yes, the 3 ton will imprint with the 1/8 in. stamps I'm using, already had the jack if I was buying one I would gwt a 5 ton or larger if you have a big stamp, I believe the stamp company could tell you how much pressure you need if you have a custom stamp.
THANKS MIKE!! I'LL GIVE EM A CALL.
