Home made surface grinder
I was ask to post more pic's of my grinder awhile, so here ya go.
I made it out of my old Kalamzoo 2 X 72 grinder.
Geo, I cant tell what that grinder looks like. Step back a couple feet and take another group of shots. Is this something we can make? I see a cross vice but what does it do? What is the magnetic chuck mounted to?
I looked at it 2 weeks ago when I was there. There are two cross slides, one adjusts the height of the wheel(Z axis) the other does X and Y (and is the one the mag chuck is mounted on) very cool setup!
-Page
I wonder how hard it would be to make something like that would hold a blade and attach to a KMG tooling arm...and then surface grind on the KMG
-Page
Thanks, the cross vice on the bottom that has the chuck mounted looks to be a bigger longer travel one. Where do you get those? It looks like a small milling machine table actually. I wonder if I could mount a belt grinder on my milling machine and use the power feed to move the table? Might be something to think about.
IG, I'm curious about the Z-travel - because the X-Y-tables are designed to work horizontally (in terms of gravity).
Did you have any problems/considerations with the tracking/play of the Z-travel?
I'm more curious about the travel along X...
Doesn't only moving .2" per revoultion mess with you?
I picture heat generation being a problem, and dwell marks...
All my experience is with a rock though, never messed around with a belt.
Doesn't only moving .2" per revolution mess with you?
As long as you keep the table moving you do not get any dwell marks. As far as heat there is no problem as long as you use a new belt. I use the 977 belt from Pop's, they are designed for high pressure applications. With a new 977 40 grit belt on it, I can take .005" per pass.
