DaveH said:
I
1) Can't have another computer with wireless in the same room.
2) Can't use cordless phone in the same room.
3) Can't use cell phone in the same room.
4) Can't run a firewall on the computer with the wireless network.
5) Can't run VPN through the wireless.
1) BS. I do it all the time..
2) BS I have two cordless phones in the same room as my notebook (which uses 802.11, and yes it's the same 2.4Ghz spectrum)
3) BS I have one sitting 1 foot away on my hip (totally different frequences)
4) BS. I do this all the time to get into work
5) BS I have both a server, and client I can run a VPN too
Dave.. I'm not sure where you are getting this info from, but it's obviously from people who do not know wireless networks.....NOW.. speaking of the problems you have.. YES.. I have had and seen the problems you have been experiencing.. there can be several causes., then most common is when the "local" card determines the speed that is being used is to "noisy" and tries to lower the speed, and does not do it properly/cleanly, and you end of with th e problem (I had it all the time)..
this is how you can see if that is the problems.. put youe mouse "over" the wireless icon on the bottom tool bar.. it should tell you several things.. look at the "speed" .. when you start to experience problems. see if the speed has dropped.. if so. then this is most likly the problem.. there are some things you can do to tweak the timeouts for noise or the retry time (depending on the card/driver).. you can also get an external antenna, (eg, I was having this problem when I was about 15 feet awat, but once I install the antenna it went away).. it has to do with the higher frequenxy ways that tend to react to the angle of the walls. (it's wierd) but I can put a book between mine, and as I rotate the book, I can see the noise singals changing..
the other thing you can do is use a tool like netstumbler to "sniff" the access point and look at the "signal to noise ratio" and when you get problems, see if the signal is low, or the noise is high (different problems which can cause th card to drop the speed and have to resetablish the connection).
Email/PM me if you need more help.
