Gary, I'm not that far ahead of you in terms of experience, so you should listen to the other posts first, but I may have a few insights. I built a brake drum forge for myself and started forging a few months ago, and as Stacy suggests, it was far easier to build than to use well. (Btw, in lieu of a hair dryer, I use a 100 CFM bathroom vent fan as the blower. It was pretty cheap, is designed to run more or less non-stop, and you can control the air flow using either a dimmer switch or an airgate). Even regulating the amount of air, it can be difficult to control the heat and you get hot spots. This can be a good thing for forging, especially if you are also interested in trying ornamental work, but can be frustrating if you are looking for an even heat. If you are primarily using the forge for the quench portion of heat treating, skip the brake drum entirely and go with gas. I have since picked up a two burner propane forge for this purpose. Other than that, read up on the basics, watch some youtube videos, and then go for it. Other than the heat treatment, where there are relatively precise temperatures to shoot for and procedures to follow, experience (and the mistakes that come with it) seems to be the best teacher.
