SkaerE, whenever you work with electricity you need to be very carefull! If you don't feel confdent doing it yourself, find a buddy that knows electricity to help you out. That is what i did, for wiring the stuff into the breaker box.
Wiring the elements is not difficult. The element that you described above, will use about 13 amps at the 120V and has about 9.3 ohms of resistance. The max temp will be dependant on the ht oven size and how well it is insultated. If you keep the element in one single piece, you will be fine. If you cut it into multiple pieces, you have to wire them in series so that the resistance is additive. If you wire multiple elements in parallel, the total ohms resistance is less than what you started with and you will melt your elements becuase more amperage will run through them. Go
here for the difference between series and parallel wiring.
I think one other thing to take into consideration is the interior size of the oven. At least how far your elements are going to be from what you are heat treating. When my ht oven was 4 x 4 x 18 i was mostly trying to fire blue the furniture for a dagger. Steel is supposed to blue around 550 to 575. I would set my temp on the the oven to 550 and would not get the color I wanted. I tried all different combinations of temp and time. What i finaly found that worked was set the temp to 750, and just checked the piece for color every couple minutes until it was what i wanted.
The only thing I can figure out is that in the 4 x 4 oven, the piece was so close to the elements that the surface of the piece was getting overheated by the radiation from the elements. With the big oven last night, I set the temp to 550, put the steel in, came back an hour later, and it was blue.
Budget casting supply sells rheostat type controllers, and other ceramics places sell the pyrometers. I use an Omega digital controller with a solid state relay to run mine. It is a smple controller, basically on and off, none of that fancy ramp and soak stuff. If i ever get into ss and other complicated alloys, i will probably buy a controller that is programable.
Anyway, let me know what other questions you might have, and hopefully I can answer them.
