- Nov 27, 1999
You don't need to use bblack pipe. Like I said above, take a lot of what he says with a grain of salt. Use the welder fitting as a jet. I bought a handful and tried each until I found the best size. You can get either 1/4 or 1/8 at Lowes in Brass and I think they have 1/4 in Galvanized. Works just as well. It doesn't get hot enough to melt it back there. On the first one I didn't have any set screws handy so I drilled 3 holes in the coupling, took three long 10-24 screws, cut off the heads and bent the ends to form a J bolt. The J held the pipe with the jet in it and in fact allowed me to adjust the angle of it.
There are a lot of ways to change the design. I have one that I used a threaded T instead of the coupling. I use it to blow air instead of having a venturi.
The mini mongo design is really a good basis for experiment.
