- Oct 8, 2013
I have started my journey into forging San mai steel. I looked around at the steel scrap I had lying around my shop. I settled on using a old airgun barrel for the outside of the steel, since it has low carbon content. I threaded the ends so i could put bolt on either end to enclose it. I swept up all of my high carbon steel dust, which ranges from 1095 to old high carbon file dust. I heated up a old garage door spring and straightened it out into a straight bar of spring steel. I put the spring inside the barrel and filled the excess space with the steel dust. I enclosed it with the bolts and started forging and fluxing. I ran out of charcoal half way through.
My question is do you guys think it will turn out ok enough to be used as blade steel? I ground the half I did flat and the welds appear to be good. It also sparks really well to. I will finish the forging on the next nice free day I have. I will post the results when I am finished. Another thing is what should I use as etchent?
