- Sep 3, 2004
Hi all,
A while back Pict was kind enough to send me directions on how to make a water filter similar to the one that he uses to prefilter his water while out and about. I had filed away the information to save for a later day since I had recently gotten a MSR Sweetwater that met my needs. Flash forward to this week, I'm getting ready for a trip out to the Verde River this weekend. My wife has moved the filter (which we kept with the emergency house gear) and we can't find it. Well a quick trip to the pet store and scrounging up some PVC and I have a new filter.
Pict has given me permission to let you know how I made it but he (and I) wanted all to know that: THIS IN NO WAY CHEMICALLY FILTERS WATER! This is at best a good pre-filter that will take out a lot of scum and crud. It should ALWAYS be used with another method of purification be it boiling, chemical drops or UV purification.
Materials used:
Activated Carbon $12
Fish filter fluff $13
Spice shaker cap:free
PVC pipe and attachment: Free from sprinkler project
I had to trim the shaker a bit to fit in the attachment, but it gave a good snug fit on the base of the pipe.
I cut a portion of the filter fluff into 1-2 inch squares so that it would pack easier, and added two over the base to keep the (now) strainer attachment from clogging. I then added several tablespoon fulls of activated carbon (until it was halfway full) and then 4-5 more squares of fluff, packed tight.
this leaves about 2 inches between the top of the pipe and the top layer of fluff for ease of filling.
I ran a few cups of tap water through to get all of the dust off the carbon, and after about 2 cups of water it was running clean.
Tonight I will mix up a nice cup of dirt water and try filtering that to see how much it clears out.
All in all, I think it was pretty good for a 1st try. It will dispense well into a nalgene bottle where I will treat it again with drops or possibly a steripen. I want to play with the design more in the future to reduce size and weight, but this should work fine for the weekend.
Again, if you use this, please add a second purifying step.
Thanks to Pict for the idea and permission to post it. I had a lot of fun making it.
Mike
Materials used:
Mike
