- Jul 20, 2021
"Artisanal firewood"
Is he serious???
Is he serious???
We're always serious 110% of the time."Artisanal firewood"
Is he serious???
To withstand regular batoning, you need a strong tip as well. That is what you are wailing on with the baton to push the rest of the blade through the wood. In both methods, there will be strong forces if the knife gets stuck in twists and knots, and you are trying to push through or extract the blade.I wouldn't be too sure .
You'd best have a very strong point on your knife and stay straight on with your battening , to avoid shearing forces .
I actually don't think that's true. The spine of the blade isn't taking a beating...It's the same stress on the blade/ lock...
It's the same concept as a hydraulic log splitter, glad we reached the same conclusion.I've been horizontal batoning for years.
Why you scandalous rogue...I mentioned horizontal batoning to my wife last night. She was cool with the idea.
But it takes... Newton says soI actually don't think that's true. The spine of the blade isn't taking a beating...
In the sense that the log is split by the blade, there are equal and opposite forces. In the method of propulsion, there is a big difference. There's much more shock when you are driving the blade with the baton; you can feel it in your hand. If you have a bomb proof knife, this won't matter. If you have a marginal knife, maybe going horizontal helps.But it takes... Newton says so![]()
Sir, 3 is invisible.I'm trying to patent Z axis batoning.
1. Hold log to baton vertical (ie. standing like a tree). Don't use your hand! Dangerous!
2. Drop open knife with enough force to split log.
3.
4. Profit.
I'm having some problems with #2.
Some people are trying their best...I thought this was going to be a dirty thread.
to stabilize the knife ( on the edge plane ) we need 2 points ( forces ), one on the tip and one on the handle. the force from the log (going perpendicular to the edge ) it wil be distributed according to the length on the knife and how deep is the tip of the knife driven into the wood. Deeper, less force into the handle. But the forces are here, on the tip and on the handle. It's easier on the hand because of this ( and because the knife it's also stabilized lateral by the tip sunk into the wood )In the sense that the log is split by the blade, there are equal and opposite forces. In the method of propulsion, there is a big difference. There's much more shock when you are driving the blade with the baton; you can feel it in your hand. If you have a bomb proof knife, this won't matter. If you have a marginal knife, maybe going horizontal helps.
Hit the wood, not your knife. You saw it here first!
Well, everybody hates somethingI see you get some flak from the guys who still think hating "bushcraft" and "batoning" is the latest hype, I wouldn't care to much about them comments.
The diameter of that baton was too big for my hand, and I had already done some vertical batoning beforehand. My hand was tired and I was losing my grip. That's why you see me switching to a two hand grip in the middle of the video.One thing I thought of, and it shows in the vid too, it's harder to hit the log as you have to be more accurate not to hit the base you're working on.
Yes, that is true. If I had done this on a stump, people would have said, "where are you going to find a perfect stump in the woods?" Like I said, this is not the ultimate skill, it's just another trick to have in your bag.You also have to find a fallen tree or something if you are doing this hiking.
Yes. My chimney flue thanks me. Clean burning. Worth every $$$."Artisanal firewood"
Is he serious???
