Im thinking 2 x 72 because of belt interchangeability. VFD would be nice, but is speed control a big concern for a horizontal?
Sean
I would be happy with a 48" belt as they cost less but it could take 72" also. Mostly just fine belts. I want a variable speed with a couple different rubber wheel sizes for inside raidius with a table under each one and a sturdy flat platen. The whole idea is to make perpendicular grinds on the profile of folding knives. I didnt even want one until I started making slipjoints.
Bruce, you have a KMG, right? If so, you could probably fab something up to use your small wheel attachment/tooling arm for the KMG so you can have changeable wheels like the Beaumont grinder.
Great pictures of some neat setups in that link, Charles.
--nathan
I dont have a KMG, but would like to someday.
I think there is plenty of wasted room on belt grinders. You have 72" of belt but we only use a couple small sections. Why not have 4 wheels of different sizes. There is plenty of room for one at each corner at a nice sized platen too. Put the motor on the bottom out of the way and use it as the tracking so you have all 4 wheels usable (rubber covered). The small wheels could be quick change and may have several sizes like from 1/2"-2".
It's going to be difficult to take full advantage of your small wheels in such a setup -- the smaller the wheel, the closer to a 90 degree corner you're going to have. Even this setup http://www.bladeforums.com/forums/showpost.php?p=5432257&postcount=6 only manages about a 70 degree angle at best. I do like the ability it has to simply rotate another small wheel into place (plus a wheel not in use is not running), but would much prefer the acute angle of the KMG. I'd also prefer the ability to use 2x48 belts to take up a lot less benchspace.
-- Dwight
Stainless?![]()
I just read the last few posts too and was thinking very similarly also.
-movable/removable tables for each wheel taken as a given
Located on dowel pins to the base makes sense to me
-footprint can be kept smaller with some extra idler wheels to snake the 72"belt
(and give the acute angle clearance on the small wheels)
drive wheel as tracking is smart, have to think a bit on that
This wheel could be kept fairly small, which would also yield a lower belt speed.
Motor mounted below - I agree keeps it out of the way and allows room to do this drive wheel as tracking
-right now -facemount motor, dowel pins...and springs with setscrews occurs to me as simple and possible
1. what size contact wheels do you have in mind?
What combination of wheels would you want on at once, without having to change the setup?
ie. a 4 inch, a 2 inch and 2 small wheels capable of various interchangeable sizes ?
Give me a clue, maybe what I have in mind is impossible, but I want to mock it up if I can to see
3. what size platen?
