- Oct 30, 2002
I picked up a 3/4 HP 3 phase motor from Grizzly the other day to use for my disc grinder. I wired a switch for my VFD output so that the same VFD and remote mounted controls control both my KMG and my disc grinder. The grinder is fully variable speed and reversible.
I will probably pick up a 54-C face motor in the future to use with the Beaumont vertical mounting plate I have, but until then, I set this grinder up to be used in both the horizontal and vertical position. I prever flattening on a horizontal surface (vertical motor mount with horizontal disc), and I prefer grinding blades on a vertical surface (horizontal motor mount). The way I mounted this motor, I can have my cake and eat it too!
I stacked and screwed a couple of pieces of 2x12" together to get to a comfrotable horizontal height, and then I drilled holes for pins that go through the work table. This holds the grinder securely when used in a horizontal mount:
And yes, that's a flat Beaumont disc on the motor with a beveled disc with neoprene/plexi covering sittin behind the motor
Since the back of the motor is flat, I cut the boards so that they were even with the back of the motor housing. This way, I can knock out the pins quickly and set the motor on it's back securely for a vertical motor mount and horizontal grinding surface:
If necessary, I'll fashion a piece of angle to clamp to the base to prevent movement in this position.
O happy days!
--nathan
O happy days!
--nathan
