Horse stall mat rubber?
oh, didn't read that first part. Does this stuff really make your hands smell? i don't care, just wondering how bad it is.
i found some at stallmats.com but there are so many to chose from. what is the best stuff? thanks for the patience.
dave
i use neoprene instead of horse stall mat and i use regular superglue to hold it on with. almost every knife that art summers gave me has neoprene and some are going on 18 years old and only 1 came loose but i didnt have the surface roughed up enough where it came loose at. i used to get this one type of superglue that cost about $40. for a small bottle but a friend who worked where they made the stuff said i could get by with the store bought glue just as well. i made a chopper last month that i put neoprene on and chopped down a few elm trees without any problems. one was at least 8" across. if you want to see the knife i just posted some pictures at my new website. http://sites.google.com/site/richardjsknives/Home/more-knife-pics-and-vids/more-knife-pictures
Gorilla Glue has a new superglue on the market that has some flexability to it and is advertised as being impact resistant. I bet it would work better than regular SG. I have used it on some projects and really like it.
$5 for two tubes at home depot.
If you live in or near a larger centre, look up gasket companies in the area.
I found a place yesterday and got 3 square feet of 3/8" black neoprene for 30.00 and a 2.5" x 5' strip of 1/4" for $10.00 to surface my grinder wheel with. I only asked for 4' but he gave me 5'.
this stuff doesn't smell quite as bad as the horsestall mat and is a solid texture not super granular like the HSM.
A lot of guys use the Tractor Supply mat. I made a test knife using super glue and no pins. Like Ian said, a couple of the Dutch smiths use thick blocks of the stuff for through tang knives. You might want to ask Toni Oostendorp how he does it. Eastvillageknives.com, IIRC.
We buy big chunks of rubber over here, the piece I bought was 2" high about 20" wide and 20" long. enough for a couple of knives. we can buy it in different hardnesses. when you use it and drill the tang out, it is a good idea to keep it as tight as possible. The rubber block will stick to the tang without glue or a pin. Off course you should use glue and the pin, but just to show how it fits.
here's a picture of a demo blade for which i used the rubber...
greetings,
Toni
