Horsewright Knives and Leather
Working in the shop this morning. We finally got some weather. This was this morning going out to feed:
That's Josie at the fence. She always knows what time it is.
Heading out to the shop to put the bolsters on for this batch. Kinda been letting my heaters run some befor I head out. This time of the year we call it the "meat locker".
Winter wonderland 🤠
Glad you got some precip.
Stay warm my friend. Nice pics.
Will be a 100f here today 96 yesterday.
Beautiful.
^ Beautiful!
Thanks!
Winter wonderland 🤠
Yes sir. Interestingly we were right at the cutoff elevation wise, from light snow to heavier. We got about two inches and right above us they were at ten. Hard frost this morning, but dry.
Thanks and man did we need it. This brings us to bout 2.5”-3” for the water year.
Yes sir! I’m guessing we had different uniforms of the day. I started with sheepskin lined boots and wool socks. Wool dufold base layer, and jeans. Wool dufold base layer, button down shirt, double layered wool vest, (Horsewright made) and a heavy fleece jacket. This jacket cost me all of $3 at a local second hand store and it is beefy. Looks like it could be the midlayer for an assault on Everest. A Horsewright silk wildrag and a wool Stormy Kromer cap finished her off. In retrospect maybe I should of been a sheep rancher instead of a cattle rancher!
Beautiful.
Thanks my friend!
I did a lot of handle prep yesterday for this batch and the weather cooperated. Sunshine and a high of 44. I like to do this outside as nothing worse than elk horn and sheep horn sawdust all over the shop. Gonna try and get some more work done today on this batch. My goals are to get the first handle side on the bolstered knives and the non bolstered knives glued up so they can dry overnight. Should have similar weather again so that should be great as more handle grinding to do.
Thanks!
Thanks my friend!
Sheepwright knives....🤔 Doesn’t sound the same.
Sounds like you might have just be warm enough. I love a good vest👍 jacket was a bargain
I'm a fan of sheepskin, vest is about 17 years old my youngest used to knock it off. You would find her on the lounge vest fully zipped sitting all tucked up, so her head was the only thing sticking out, very cute. I do have ugg boots, sheepskin gloves and if it's really cold sheepskin beanie. The sheepskin factory is only 50 minutes away with a factory outlet about 20 minutes.
Makes sense doing as much as you can outside sounds like you are busy. Past 2 weeks we've been getting severe summer storms, another thunderstorm expected later today.
Have a great day!
Hopefully some of that water will be flowing down from upstate to you.
Yeah they sure get more up that way than we do. I was talking to a friend that runs a ranch up there. He got 28 inches out of one three day storm!
Have a great day!
You are absolutely right, Sheepwright just doesn't have much of a ring! Yeah those boots are cozy! Mine are Uggs too, a lace up style like a chukka boot.
So I've been processing the handle materials for this next batch. The sheep/ramshorn scales get their liners glued on. The glue I use needs a full day to cure so these liners are one of the first things I do when processing handle materials. In this pic from the bottom a set of rams horn and then two sets of sheep horn and another near the top next to that very nice block of ironwood.
I sand down the scales on the inside prior to glueing. Otherwise you could lose all the texture when shaping the handle. Also, you are gonna have some imperfections to sand out usually too. Here's a nice set:
If the liner color has been specified (an order), then that is noted on the tape. This Mestano is gonna get green liners on its rams horn scales:
I use an old fashioned paper cutter to cut the liners and I do the spacers for the bolstered knives at the same time.
The liners will be numbered so that I know what set goes to what knife:
Next morning I unclamp all the scales and then the excess material needs to be trimmed off.
This lil portaband saw on a SWAG table is a workhorse. I had a large free standing 14" bandsaw. I gave it away years ago. This will cut everything with a simple blade change. 10tpi for handle materials. 14tpi for steel and other metals.
I'll take the scales to the flat disc to get the burr off the liner from sawing the excess off. I do this without the flat disc running as it's easy to grind too much liner off and screw up your flatness. Ask me how I know. Just rubbing it back and forth on the flat disc will take care of it:
While those were drying yesterday, I got busy on some of the other materials. I had a few knives in this batch that needed very large elk scales. I didn't have enough large ones in my elk box so I had to cut up and process a small batch of scales. When I do this to fill up my elk scale box I will do two or three times as many as I did here.
Thirty five minutes in a potassium permanganate bath and drying:
Couple coats of a clear coat and they are good to go:
Cut up some wood scales too. Here is a set of what I call "Historic Oak". From an old bran in MO, from the 1800s, that fell down. It was in a friends family and he gave me a board to use from the barn.
Damped with a paper towel and it shows better how it will look when finished:
Sorry for the paper towel fuzzies but it definitely has more life now.
Well I got everything glued up yesterday and so will be shaping handles today.
Great group of knives.
The big fella is not usual stock, nice!
Thanks for sharing Dave.
Thank you. That big one and the one below it sorta centered, are Green River blades. Had a cowboy here in the shop a few weeks ago. He saw the other two I’d done some while back for another local guy that I’d traded for some elk sheds. While he was here he kept handling the other one’s I’d built inn trade. So he ordered his own set. I’ve got some Green river blades left but thats the last of those small ones.
Cowboy AEBL Buckeye Burl
Mestano AEBL Walnut
Apologies for never posting these, Mr. Ferry, I purchased the Cowboy off the site during an absence from the forum; then I am not good with pictures, back when that was being worked out.
I keep a list of knives I might like one day, and for maybe five years, it has included "Gordo". So, naturally when it came to decision time, I chose the Cowboy off the site (I like burls). Then, choosing a smaller option, of course went with the Mestano. Compact and punch way above their class.
The leatherwork is excellent, there's evidence that I strop with the edges (Cowboy sheath).
Do your SIG holsters accommodate P365 XL RZ (romeozero)?
Mestano AEBL Walnut
View attachment 2784029View attachment 2784048
Great pics! I remember the cowboy. Hadn't really done one in buckeye burl with the same spacer before. I liked how it came out. Thanks for the kind words. No on the holster. We can accommodate the 365 xl but not with the optic. Just too many variables to get the fit right without having the weapon in hand. Literally working on a Gordo sheath right now as there will be one in the upcoming batch.
I had to attempt to make a new lanyard for this one. It's not quite as well done as Dave's, but only took me one fatal mistake on the first and the second didn't turn out too bad. I have to say this knife is one of the best cutting blades I have.
Well you did a great job! And thanks for the kind words on your knife. That looks better than many I see. Getting a lot of other maker's knives in to do sheaths I see a lot of this done and I probably see this knot done wrong more often than I see it done right. In the western world this is referred to as a blood knot or a bled on knot. There is a real blood knot and I use it fly fishing and for changing colors of thread on my sewing machine. Tie the red to the white with a blood knot and pull it through. Now your machine is threaded with red thread. Gotta remember to change the bobbin too, of course but there ya are. So our western blood knot is used in saddlery and there is a special tool called a bleeder to do this job but an exacto knife does just fine. I have two bleeders and use the exacto knife. If you ever want to put a new string on one of my knives or on someone else's here's a lil tutorial I wrote last year for knife makers over on the other side of BF:
Great pic too btw. I've got two cap and balls. A 51 Navy and a 58 Remington. I don't make a lot of them but I enjoy making California Slim Jim holsters for them.
