- Aug 1, 1999
Over almost 20 years of making knives, I have had maybe a half dozen or so belts break on me. Most were Hermes that seem to deteriorate with time and any atmospheric moisture. Today, a 36 grit belt from Industrial Abrasives broke, removing the surface of one fingernail. Clearly it could have been worse, and has in the past. A fresh 60 grit Hermes popped on me once and removed the back of my little finger.
I only use belts from producers other than 3M for finishing handles. All my steel is ground with 3M's best. For hogging off wood or micarta, which clog belts pretty quickly, I use cheap ones and throw them away as soon as they fill up.
The belt which broke today was almost new, and snapped without warning. Some of the time you can hear it coming. There is a brief flapping sound before it cuts loose. 3M's Micron Belts make a lot of noise before they break, but I don't use those since they came out with the Trizact line.
OK so what's the "hot tip"? The tip is that it only hurts for a little while and all wounds heal. Most of this was just to vent my frustration. Thanks for your time.
Jerry Hossom
www.hossom.com
Jerry Hossom
www.hossom.com
