Hot topic from Outdoor life Mag.
Fire Starters
These materials can be found almost anywhere...from the woods to your laundry room.
Oct 15, 2007
The hardest part of building a fire is getting it started. Once you have a nice bed of white-hot coals, keeping it going is a piece of ashcake (bad joke, I know). But getting to that point can be frustrating...unless you use some kind of fire-starting magic. And indeed, there are many tricks you can use to induce ignition. Some are store-bought, others are natural and still others are homemade.
Store-Bought Starters
(1) WetFire: These small, individually packaged dry pellets of compressed fire starter can be shaved into a tinder bundle or broken up and spread among kindling. They instantly catch and hold a fire when either a flame or strong spark is applied, regardless of altitude or nasty weather conditions.
Pros: Burns very hot (over 1,300 degrees), even when wet.
Cons: None.
(2) Fire Paste: This is an effective commercial imitation of pine sap. Smear it into a tinder bundle or wipe it on some kindling, then pile more kindling on top and light it. The paste is volatile and will catch a flame quickly and hold it long enough for the tinder or kindling to dry out from the heat.
Pros: Like WetFire, this stuff works every time, regardless of the bad weather or extreme temperature.
Cons: The tube is bulky and can be a bother to carry in your pocket.
(3) Fire Sticks: These sticks, which imitate natural pitchwood, are made of compressed sawdust and infused with an accelerant to help the solid material catch and hold a flame. Break up the sticks and insert them into a pile of loosely stacked kindling, or crumble them and add to a tinder bundle.
Pros: They will catch fire even after being submerged in water.
Cons: None.
(4) Candles: Some folks like to carry an emergency candle, as it will hold a flame after a match has died. One of the benefits is that the melted wax can be dripped into other fluffy tinder materials to augment their flammability.
Pros: The wick is easy to light.
Cons:
: A candle will blow out with the slightest puff of wind. Also, candles can be bulky.
Natural Starters
(5) Pitchwood: When sap floods into a tree wound, permanently saturating the root, trunk or limb fibers, the wood becomes heavy and brittle as pitchwood is formed. (Commercial substitutes, such as Fatwood, are available at many hardware stores.) A few slivers of pitchwood stuck into a tinder bundle or in among the kindling almost guarantee success in starting a fire. Sap itself works well, too.
Pros: Burns even when wet.
Cons: You have to find the stuff, which can be difficult. Look for an old, injured tree. Dig into a decaying stump and, if you're lucky, you might find the hard, dark, heavy pitchwood. Sap is easier to find.
(6) Bird's Nest: If you can find one, these are ready-made tinder bundles.
Pros: As long as it's dry, a bird's nest is hard to beat as a natural fire starter.
cons: Birds don't build their nests within reach of ground-based animals. If you do find one, make sure it isn't inhabited.
(7) Dry Grasses: You can make your own bird's nest by twisting dry grass stalks together into a tight bundle.
Pros: You can find grass everywhere.
Cons: The grass must be absolutely dry or it will just smoke when lit.
(8) Shredded Tree Bark: Some trees, such as juniper and cedar, have an inner bark layer that can be shredded and also twisted into a tight tinder bundle.
Pros: The pliable bark is easy to work with.
Cons: These trees aren't in all forests.
(9) Pine Needles: Scrape together a mound of the driest needles and pine duff you can find. If there's sap on them, so much the better: It will make the needles catch fire more readily. Pros: Easy to find in most forests.
Cons: Sometimes the smallest pine needles can be difficult to ignite.
Homemade Fire Starters
(10) High-Powered Cotton Balls or Dryer Lint: For this trick, you can use either cotton balls or lint you've pulled out of the clothes dryer filter and made into a cotton-ball-sized wad. Saturate the ball with melted candle wax, then compress it into a marble-sized pellet and store it in a plastic bag or a plastic 35mm film canister. An alternative is to saturate the ball with petroleum jelly. When the pellets are lit, they will burn hot and long. Cotton swabs work, too.
Pros: Small and lightweight; easy to stow in a pocket; not volatile.
Cons: None.
:D I know this topic gets brought up alot but this info is so good ,& some folks may have missed this a time or two ..any whoo !
Good thread. I bought some firestarters a few days ago to try out on a quick overnight next weekend. I'm not sure if they are exactly like anything on your list. They seem similar to #2. I'm looking forward to seeing how they work.
You can buy boxes of fatwood/pitchwood. I bought a 3 lb. box at Lowe's a couple weeks ago for about $4 or $5. It contains enough fatwood to start many fires.
Around the holidays, most of the hardware type outlets in our area carry fatwood sticks either in 3# boxes, or 2# packages, or both. Cost is relatively low and the stuff is great firestarter.
try cottonballs with petroleum jelly or shoe polish worked into them. burn time can be adjusted by pulling/fluffing the firestarters. they burn 5 to 10 min.
Thanks for posting that TT.
For Outdoor Life to publish that without even mentioning magnesium is akin to them talking about North American big game species and omitting whitetail deer! :rolleyes:
-- FLIX
I carry around my *psk* in my altoids tin with me everywhere. In it I have my magnesium bar, lantern flint lighter, cotton balls, a 'just add water' towelette which starts as a pill and turns into a 10"x10" rag, a small tube filled with: fishing string, hooks, weights, sewing kit, and matches. I think the magnesium bar and flint striker will work out fine for me. Good luck with your kits, J.
As good as magnesium is, it does have a severe drawback. Burn time. You will still need something that is easily lit by the extreme flash heat produced by magnesium.
.02
J.
I tried magnesium one time. I piled my kindling, put down a piece of bark and started scraping. Most of the magnesium blew away in the wind but after a few minutes I tried to light my bundle. Nothing happened. The scrapings were too scattered and impossible to light.
A cottonball soaked in Vaseline and a "Hot Spark" work much better for me and get a fire started with only one scrape.
Chad
Guys, my point wasn't to promote the mag bar above all other tinder sources. It was to point out that in such an article, the magnesium bar certainly deserves mention.
As to the merits of the mag bar, as has been stated well in other threads recently, it is waterproof, virtually unbreakable, utterly reliable and it burns incredibly hot. On the "con" side, it requires a bit of a learning curve and has a very short burn time. I would never argue that a mag bar should be your primary firemaker, but it makes an excellent backup.
-- FLIX
For what it's worth -
WetFire: CON and a BIG one. My first and last experience with the much lauded WetFire was that they did NOT LIGHT. Not with a firesteel, not with a wooden match and they did not light WITH A BIC LIGHTER held underneath them with flame enveloping them. Yes, they were in the sealed package that I tore off before trying them.
I bought 2 boxes of them and after trying 3 different ones - returned them to the store for my hard earned cash. I am done with WetFire. I am an old fashioned traditionalist and have never been fond of gimmicks. I only post this for the benefit of others. Perhaps the ones I bought had been on a shelf for years - who knows and who cares. Point is - they FAILED TO LIGHT at home on a nice day - NOT when my life depended on them. I'll stick to my decades old non-gimmicks... Be careful out there.
I like the cotton ball (I steal my wifes cotton make-up remover pads) petroleum jelly and keep about 10 of the saturated buggers in a film canister.
Question - the fatwood at hardwood stores. This isn't those compressed firelogs is it? I often wondered about this because they are basically paraffin wax holding together sawdaust. BTW when I'm doing field work and know I won't have time to screw around with finding fire wood at night, I usually bring along a case of these things. As long as you aren't one of those 'gotta poke the fire' types, a log will last between 2-4 hours. Last year I baught a case of what was called Java longs that were made out of compressed dried coffee grounds. They worked great and actually smelled a bit like coffee!
Hey Guys..
Flix..
Yaa it is kind of funny they missed the mag bar Eh..
Personally though I think magnesium is a little over rated myself..
Sure it works and works well,, however I reach for a mag bar the least..
Great to have everything you need in one package, and I'll always have one with me,, however they are alot of work...I'd much rather use fatwood and a ferro myself..
ttyle
Eric
O/ST
kgd: No the fatwood you get at the hardware store is just like the pitch wood mentioned in the OP. They are sticks of wood approximately 12" long x 1" square, and they are completely saturated in pine sap. Look for it near there firewood, and compressed firelogs and firestarters.
Scape them with your firesteel striker, or with your knife held at perpendicular to the stick, so you are scraping shavings off and not slicing shavings off. I hope this makes sense. Get yourself a nice pile of shaveing, roughly the size of a quarter if not larger, and it will catch easily with a spark, but may take a couple of strikes to catch. Not quite as easy to start as PJ cotton balls, but pretty darn close, with the added benefit of being completely watter proof.
They are waterproof, reliable, and burn for a long time. You can also use some larger slivers as your next step for kindling.
Quick question- did you pull them apart or just light the cube- they take some preparation before lighting.
