Let me see if I have this straight:
You don't want to use a known piece of "barstock" that you know will make a good, usable knife, but you don't want to "practice" on anything around the house unless IT MIGHT make a good usable knife?
Not sure I follow the reasoning there.
I'm not sure what your other thread was about, or what was suggested there, but trust me... The minimal cost of buying a good piece of carbon steel flatstock far outweighs the wasted time and headaches that come with trying to make a knife that MIGHT be usable after you attempt to heat treat it.
Consider this:
You find an old file rusting away behind the workbench in your shop.
You spend an hour or so building a fire in the back yard and getting the coals hot enough to take your mystery file up to critical temp.
You then bury said file in some vermiculite and come back several hours later.
You start filing, drilling, and hack sawing this mystery piece of steel, and 6 broken/dull drill bits, 3 broken/dull hacksaw blades, and 2 dull files later (not to mention about 10 hours worth of cussing, spitting, kicking, and wondering why the heck anybody could ever find this enjoyable), you have something that might half way resemble a knife.
A glimmer of hope appears! Now it's time to heat treat!
Spend another few hours using your heat treating method of choice, tempering, and cleaning scale off of your new found labor of love, and then another 5 or 6 hours putting a handle and an edge on your knife, and then sit back and admire your creation. Now it's time to test the edge!
After about 5 minutes of cutting cardboard, rope, and whatever else you can find to decimate around the shop, you realize the unthinkable:
That file was case hardened mild steel. Congratulations. you've now just wasted 47 hours of your time, about $36.79 worth of drill bits, saw blades, and files, and to top it all off, you've turned yourself off of knife making forever.
Buy some good steel.
If you absolutely feel like you need to practice, go to the scrap yard and get a few pieces of scrap flat stock that roughly mimics the dimension of 1084 that you're going to buy from Aldo after reading this response, and file, drill, cut, and grind on that until your heart is content. Then use the left overs for templates for your real knife.
