- Jun 14, 2012
I have two knives that came from the factory with two different bevels, on one side the edge looks normal but on the other side the edge is very thin in a section near the tip. They are both recurve knives but the problem is not inside the recurve, its near the tip.. which is the straightest part of the edge. How can I fix this so the angles are the same on both sides and so the edge looks identical on each side? Im assuming Ill have to reprofile the thin side, which is not a problem, but when I widen the edge and start grinding off some of the coating will it chip away or come off nicely? One knife is satin so Im no so worried about that one, the other is bead blasted though... will that coating come off during reprofiling without any problems? Any and All advice is welcome and much appreciated.
