I believe tractor supply was also offering the same knife a few years back, but I never imagined HF offering it.I've seen the Buck 110 knock offs but was pretty surprised a retailer as big as Harbor Freight is selling these 119 clones. Why anyone would buy this stuffonly to save a few dollars really blows my mind .
whole thread on it already in Buck forum.....
www.bladeforums.com
www.bladeforums.com
I know what you mean. Some of the stuff they sell is completely useless like sandpaper and files to name a couple.They’d be better off concentrating on selling tools that are worth a.
The ONLY things I buy there are pneumatic tires and battery float chargers.I know what you mean. Some of the stuff they sell is completely useless like sandpaper and files to name a couple.
It could have been the tractor supply example your friend has.I looked at one of these in person.Hickory n steel was right. its the same full tang as a Buck 119. has pin and all in it. the clones guard is tight and cut well. no micarta spacers in the clone. couldn't tell if the blade to tang transition at the guard is radiused or not. think so but not sure. knife is very tightly put together....no gaps to see. actual blade is much cheaper finished. where Buck has angles on the clip in false edge bevels.....the clone is cut flat across.
the sheath is thin leather or false leather, not sure. very thin cut so I expect it will tear or wear out fast..no surprise there. knife weight makes it tip around on a belt more than it should. it may look a bit like a Buck sheath it aint a good copy.
isn't mine so I couldn't test steel on file or sharpening to see if soft or hard.
all in all very cheaply made clone. I dont see it cutting into Bucks 119 business much. someone who wouldn't buy a 119, would buy this one. not so sure it would happen the other way other than pure curiosity.
what caught me by surprise is how available these are. in stock at every harbor f around here and I knew someone who had one already. not sure how long they've been out there...I figured newish, but no so sure now from a quick store trip and online check of stock.
he said harbor freight. I asked. good points though.It could have been the tractor supply example your friend has.
All I really know is that a TSC 119 knockoff was mentioned in the fakes and counterfeit thread a couple years ago.
I do not recall of they were as close of a copy or not.
Your assessment of the knife is about what I assumed, Walmart already sells the 119 cheaper than you'd expect and I cannot imagine China being able to offer the same exact everything in a knife for as low as $20.
Excellent investigative reporting jb!I looked at one of these in person.Hickory n steel was right. its the same full tang as a Buck 119. has pin and all in it. the clones guard is tight and cut well. no micarta spacers in the clone. couldn't tell if the blade to tang transition at the guard is radiused or not. think so but not sure. knife is very tightly put together....no gaps to see. actual blade is much cheaper finished. where Buck has angles on the clip in false edge bevels.....the clone is cut flat across.
yes Sir. i still got it as I borrowed it to look it over...was gonna post pics showing the bad but decided I didn't want to encourage any drop by folks into wasting their money by accident. if they do stop by here......id say spend the extra 30 or so bucks at Walmart or whatever is your easiest source and get a real Buck. made in America with good steel, good heat treat and lifetime warranty........y'all already know this...so that aint for y'all. i don't need to be preaching to the choir.Excellent investigative reporting jb!![]()
