I am doing some test myself and looking and reading up more info on how to Control Heat from LGP gas temperature using Passive way.
What am i saying . i am working With O-1 Steel and knowing 787C- 815C is best for Hardening it .
i am hunting for way to control the Heat of Any LPG or Gas burner .
here a few idea. hopefully Creative enough .
1. Salt is Said to MELT at 801C
2 . Lead Melting Point is 600F
3. Copper - Melting point 1083.4°C ( D2 Passive control )
4. Silver Melting Point 961.78 °C ( other Steel )
5. Gold Melting Point is 1063°C ( you can jolly well buy a good Oven if you going to use Gold . so is very much out )
I am trying to work out some way to Control The Heat using Known Info or how Heat is transfer from one material to another .
Sharing this idea so we can all produce better Knife .
Few Gabaski Idea . -
Firing Up the O-1 Steel on top of Another Metal or material . using that as a passive guide for what is needed .
Adding known Melting Point material on it or over it or on conducting Surface to Passive control the heat that is Needed .
of cos all this is when the option of High tech digital Read out is not an Option .
