I have a good idea how to build a 2 brick forge
Would I need to build a forge of some sort to be able to get both metals up to temp to harden them correctly?
If you're going to be using a forge or a simple torch, pick 1084. Look at the stickies for details but basically: it's deceptively easy to get O1 sort of hard, but you can't get to its real potential without controlled soaking at 1475-1500 F.
Best post in the thread.....Patrice Lemée;7329984 said:Nope! You just can't do it. Impossible. Never been done.
Wait maybe I am wrong. I should read some of the stickies at the top to find out.
Patrice
Is it possible to make a knife without forging or heating the metal? Can you take a file, for example, and use a grinder to make the knife? Thank you.
Well..yes and no.
No if you start from scrap metal (like a file). The hardness, or lack of it, will not keep a edge. A knife-like-object can be made from a file...or even cardboard
Yes, if you start with a knife (hardened steel) and make something custom out of it. Has been done many times on the forum and by me. For example: I turned a Cold Steel GI Tanto info a more compact clip-point. Although this follows the definition of ''customisation'' instead of ''making''.
