I just mention what is routinely observable:
That's curious, because chopping, edge angles and bevel thickness are never mentioned once in the entire article. In fact the term "edge geometry" does not appear once. Amazing what can be read into things...
I'll tell you what I took away from it:
Quote: "
It is very common for custom knifemakers to use cryogenic processing of their steels which eliminates most of the retained austenite in the steel. I wrote a forum post about what retained austenite is and what cryo treatments do. Toughness testing usually shows an increase in toughness with greater retained austenite, as can be seen in this figure for 440C [5]:
However the concern sometimes is that through stressing of the steel with retained austenite present that the austenite will transform to (untempered) martensite and therefore the brittle phase will act to reduce toughness. However, fatigue testing of material paints a different picture, where the retained austenite containing steel, which converts to martensite during cyclic loading, has higher resistance to fracture."
Translation: In attempting to make things better (and more expensive), custom makers often make things worse...
Quote: "
Another conventionally cast steel with a lower carbide volume, however, showed superior resistance to fracture due to its higher fracture toughness from a small carbide volume combined with a relatively large average distance between carbides."
Which is interesting.
My favourite though is this:
Quote:
Therefore side loading requires less stress to fracture the edges and chipping can occur along the carbide bands [15]:
If the knives are oriented along the transverse direction instead, then the tips of the blades would fail more easily in a similar fashion"
This all by itself could explain the discrepancy in my first photo: It probably should be a major item of knife choice to decide how the blade is oriented to the rolling grain.
Since most customs are preoccupied with overall strength, they are likely cut along the grain. Since cheapo factory knives don't care, or go for the easiest layout, they might be cutting them perpendicular to the grain, resulting in superior edges.
Yes there is a cost in point strength, but it can be alleviated by point design. The primary purpose is to cut after all... I have to say that generally, if you exclude a Randall Model 12 and its unique forged stainless (which was not much better than equal), I have never seen custom knives that out-performed good factory knives with equivalent geometry. The prevalence of CPMs in customs, relative to cheaper "conventional" factory steels, has made this discrepancy even greater...
Gaston
