- Aug 27, 2004
I think James hit it on the head. The liner and frame lock both seem plenty strong and most I've looked at even held up to spine whacks pretty well. Many times they performed better than lock backs for this but they don't do as well for sideways or lateral torques for a lot of guys that test them and this is the reason they are not liked much.
The frame lock has more mass usually and it therefore theoretically has more surface on the blade that needs to slide off the blade from a side torque in order for the blade to come free or the lock to defeat. In other words even if the frame lock slid a little there should still be plenty of lock behind the blade yet vs a thinner liner lock that can't move much before its below the needed metal there to keep the blade secure. So, with your hand there preventing the lock from moving on a frame lock, (something its prevented from doing with a liner lock because the lock side handle scale is in the way) the frame lock is far more trustworthy under those kind of torques or 'white knuckling' as James mentioned.
The only exceptions with liner lock folders that I've noted to this rule of the frame lock being more reliable are with ones built like this one I'm showing a pic of. Note how Bob Terzuola, the maker of this knife, did the lock side handle scale. You might also note that this is a left handed knife with the lock reversed on it. This knife belongs to a forum member. He sent it to me a while back for that low rider clip on it that I made. You can see that Bob has done a cut out of the lock side handle scale exposing the lock. In many ways this lock up, although technically a liner lock, has all the advantages of the frame lock and as a result of this method of doing the handle scale it makes the knife more trustworthy under heavy loads.
After noting this technique I have noticed other makers doing this also on at least some of their liner lock models. Its a good idea if you ask me. Putting the lock out there even more may make it that much better. Some of the other good ones seem to be those that are made to stick up higher but it seems to me the more lock you can get your hand behind the better it will be for reliability. I would imagine that it would be a simple matter to do a cut out like this on the handle scale on just about any old liner lock that you could get the lock side handle off of to make the knife just a bit more reliable for you.
STR
STR
