In my opinion after 50+ years of using knives, blade play is the most over-blown topic of discussion you can find. A small amount has virtually nothing to do with the function of a folding knife, and the more critical people are of this inconsequential "flaw," the more they are likely to be disappointed. If I can't feel any movement when using the knife, then it doesn't have any play as far as I'm concerned. This grabbing the tip of the blade to the absolute maximum of mechanical advantage and then twisting the knife to discover the wobble is silly. No one uses a knife in this fashion, so what difference does it make. Unless it has wobble during normal use, then pay it no mind.
I think a cutler with good attention to detail will produce a knife with hardly (if any) blade play, but think about what we are looking at. A steel blade(s) sandwiched between thin strips of metal often brass (but maybe some other metal) and a couple of bolsters. Then you take a pin (usually nickel) and pound it to expand and hold everything in place. If used, I think you will eventually have some play. I'd think that temperature variations will have some effect on the joint as well.
Slipjoints have been like this for ever. Unless it really just wasn't put together care, I wouldn't worry about it too much...... unless I paid a bunch of money for a new knife.
Woodrow, I think your on the right track. My sense (could be wrong) is that slip joints arose as companions to fixed blades. Modern flippers like OP is used to have been made to be concealable fixed blade replacement. That's a poor over simplification, obviously. But you get my drift. When I think of real hard use traditional folders, I think of thing with super big pivots like a sod buster or non flush pins like the Opinel. Big folding hunters like the Buck 110 work fine as hunters, but they'll open up if pushed hard.
The flat peened pin construction just has limits that need to be understood. Plenty strong for most things. Nothing wrong with that and a lot good.
Yup. If you need a really tough folder, you really need a fixed blade, IMO.
of the ~80 traditional knives I have owned (GECs, Case (old and new), Queen, Bertram, Robert Klaas, SAKS misc. older knives), none have had even the slightest amount of blade play in any direction, I never worry about it, and am surprised that others in this forum encounter it so often.
This. ↑
If I have to grab the blade and wiggle it to notice the movement, then it really isn't there.
And based on that definition of "blade play", I don't think I've noticed any blade play in any of the traditional slipjoint folders I've purchased in the last few years.
Anybody coming from a "tactical/modern" knife world when they refer to blade play they mean being able to grab the blade and feeling ANY wiggle when moved side to side or up and down. That kind of movement is generally considered unacceptable in that world.
