- Dec 27, 2013
I understand and agree with you. I'm not arguing whether some don't need to be. My quandary is which ones might I have issues with in my area? Most of my knives are meant to be used outdoors fishing, hunting, and for bushcraft.
To find the ones that are suitable I would need to experiment with different woods to see how they will act. With the amount of beautiful stabilized woods available I don't see it making sense to go through that potentially costly trial and error process.
Me either, but here's my 2 cents from experience with my spalted maple...
Cactus juice works best for punky wood due to the vacuum, whereas K&G's high pressure process will warp or crush softer pieces....
~billyO
K&G uses pressure only? Or vacuum then a soak at pressure?
Not all wood needs stabilizing, lots of exotics are fine without it
No, K&G's pressure system will not crush punky wood. The wood is first vacuumed out while resin is injected and then the pressure is increased. Punky wood is porous so the air is evacuated during the vacuum, the cells are not crush
K&G uses both vacuum and pressure. If you have questions and concerns about stabilizing i can make a post about that. This is about business advice and what you would like to see on my website.
