- Jul 30, 2006
So this is the info I'm going to rely on:
1) I wont heat the Al anywhere near melting. Just enough to decrease the min. bend radius (i.e. increase malleability?). Butane lighter or gas stove for couple minutes.
2) One expert said the clamp is probably 6061. Another expert said 7075. Both recommended against bending.
3) Correct me if I'm wrong, but the clamp definately doesnt compare to Al sheet-metal.
4) there is no glue/epoxy/adhesive as strong as the Al itself; and Al cant easily be soldered/brazed.
5) The discussion is rather academic now; Any method will be hit-or-miss; I will probably ruin this clamp, buy another, ruin with different method...
What I'm still interested in is this:
the terms O condition (soft), T3 state, W condition (unstable)...
What scale or series are they members of that I can google?
1) the butane lighter isn't a good method, the heat will not be even. If you have an oven that will hit 500F, that would be better.
2) It is unlikely that the clamp is 7075. Not a common alloy outside of aerospace. 6061 is a pretty common alloy for all sorts of things and would be my best guess as to what your clamps are. And I recommend against trying to bend it as well.
3) Talking alloy, not form. what he said about bending aluminum holds no matter what the form.
4) So, does it NEED to be as strong as aluminum? All you are doing is holding a knife. That doesn't take ultimate strength by a long shot. Remember, in clamping, you are pressing down on whatever you bond to the clamp, so there is little stress on the bond itself. The stress won't be tensile at all and there will be little peel stress either.
5) True.
O and W are not a scale. They are metallurgical heat treat terms. They describe the properties a metal has when it has a specific crystal structure. The crystal structure is what you are modifying when you heat treat.
aluminum "heat treat"
and see what you get.
