Right or wrong I think I'm going to grind the outside to follow the core so the entire blade is wonky, then try to forge it flat without crumbling it apart.
Can't see how to forge it straight without getting some material out of the way
Yay that worked. Took a few tries running between the forge and grinder and etch tank but now I've got a rough ground blade with a centered edge and core, with a simple warp.
Nice, that's what I was going to recommend you do. Happens often with san mai that a little adjustment like that is necessary. Cool blade! CruV makes the best cores...
