Ah shit
4 cracks
4 cracks
Ouch! Kinda cool how it sort of follows the lower spots on the clay though.Ah shit
4 cracks
Quenched at too low of a grit too... Those deep scratches are points where stress accumulates, makes them more prone to cracking, especially if you're doing a brine quench.I grinded way too thin than i should have, my bad
Thanks for that info, before i hand sanded to 220 but i tought i might just skip it this time, major mistake, i guess you learn from mistakesQuenched at too low of a grit too... Those deep scratches are points where stress accumulates, makes them more prone to cracking, especially if you're doing a brine quench.
I'm not sure that's the issue here. In my experience when it's a scratch acting as a stress riser it's usually pretty clear. I think this looks like cracks from stress induced by the quench, and maybe the edge was overheated.Quenched at too low of a grit too... Those deep scratches are points where stress accumulates, makes them more prone to cracking, especially if you're doing a brine quench.
I don't necessarily think that is the issue here either. However, if you're going to do a risky procedure, it's better if you eliminate potential problems and set yourself up for success.I'm not sure that's the issue here. In my experience when it's a scratch acting as a stress riser it's usually pretty clear. I think this looks like cracks from stress induced by the quench, and maybe the edge was overheated.
As Stacy said, if you insist on water quenching low hardenability steels you'll get some cracks. You can learn to do it somewhat more reliably, but it's just a risk of the process. If your goal is no cracks then get some O1 and canola oil, if you're goal is good hamons then you'll have to deal with some cracks.
Check out Jan Hafinec, a bladesmith from Slovakia. He is the hamon king, IMHO. He uses C105 carbon steel which is W1 if I recall correctly. He may be able to point you to where it can be obtained.I want to buy W2 steel, but i just cant find any in Europe, like NOOOOOONEEE, i have scoured every damn site and no one has it
Just a note, NJSB was able to source an order of White paper and blue paper steel directly from Hitachi and has it available right now in the US.I had typed that the grind was not the issue ... the quench was ... but deleted that part and made a shorter post. The cracks do not seem to propagate from grind lines. They are caused by the stress of structure changes causing the blade to try and curve in the quench and immediately after. It literally rips the brittle edge apart.
Even with Parks #50 I crack a hamon blade every now and then. In brine quenches it can be 50% or more. The results can be great, but the losses are heart wrenching.
Using a better choice of steel for a high intensity hamon in a brine quench is the answer. A low manganese W2 is a good and low-cost choice. Shopping around and requiring a cert sheet on the batch you will be purchasing from is what you need to do. Once yo find a suitable choice and test it with good results ... buy a LOT of it and refine your HT methods to get te best hamon and hard edge.
Hitachi White steel can take a brine quench.
What you want in any brine quench steel is .70-1.30% carbon and as little manganese as possible, preferably .3% or less, no other alloying, and as few trace elements as possible.
26C3 has lots of carbon (1.2-1.3%), a bit too much Mn (.5%), and an undesired .4% of Cr. The Si is from the manufacturing process and can't really be lowered much.
Why can't we get a simple low Mn high brine quench carbon steel???
Because the way steel is made the raw material is largely scrap steel. It already has the unwanted stuff in it, and it can't be removed affordably. Even making the steel from a virgin melt is tricky because some of the elements are needed for the process. I doubt all the knifemakers in the world who would do hamon blades would be a big enough market to make a single batch worthwhile.
If Larrin wants to cajole Niagra into making a batch of steel with .85% carbon and .2% manganese, I guarantee I and others would buy the whole batch. It was discussed with Crucible once before, but there was no interest by them. Hitachi won't ship sword/knife steel to the US. We tried to order 15,000 pounds once and they would not do it. We buy Hitachi shipped from Europe/UK, or order from another steel company's closest alloy.
You may note I don't call it a water quench. Water quench is the technical correct term, but the water is a brine solution of around 8%-10% salt. Many new smiths misunderstand the term and use plain water.
I saw this. I was looking for some more steel since there is no 26c3 in Australia at the moment, but importing stuff from the US is really expensive.Just a note, NJSB was able to source an order of White paper and blue paper steel directly from Hitachi and has it available right now in the US.
workshop heaven UK or eurotechni FR has 135CR3/W2I want to buy W2 steel, but i just cant find any in Europe, like NOOOOOONEEE, i have scoured every damn site and no one has it
Thank you so much for pointing this out, I haven’t ordered from them since I moved out of NJ. It was so nice being able to just make the 30-40min drive and pick up steel from their office. I was considering ordering a bar or two of white steel from dictum for my birthday or Christmas. I’ll cross check his pricing with dictum’s later.Just a note, NJSB was able to source an order of White paper and blue paper steel directly from Hitachi and has it available right now in the US.
