how do i keep paracord from fraying?
hmm guess its not paracord but its of the same design just natural fibers.. i guess im gona have to do some sort of glue.
hmm guess its not paracord but its of the same design just natural fibers.. .
That isn't close to paracord. That is just some sort of string.
This is paracord:
Try heating up the tip on some needle nosed pliers then squeeze the ends. We use that technique to make steelhead slinky's using cord that looks very similiar.
Strange. Paracord is synthetic and should melt. If it won't melt, a knot would be my suggestion but I'm sure there's a better solution.
There is a better solution to a knot, if you don't want to melt it. Heat-shrink tubing.
I wonder if the OP really has 550 cord or something fake, since it won't melt?
EDIT: Didn't see the pics of the non-550 cord.
Also, I'm a big fan of 550 cord, but there are stronger, lighter, and less stretchy rope available.
Amsteel Blue 1/8" is rated at 2,300lbs and is lighter than 550 cord, and can be found for $.24/foot.
Interesting thread...
I have had para-cord that bubbled when I burned it, but it always melted...
Just for the sake of the discussion, because I see you guys have already diagnosed him...
I like to burn/melt paracord with a match... I make sure that both the mantle and the kern are burning and molten..... I extinguish them with a puff of air..... Then, I use the match head to remove extra material, pulling away from the rope, and twisting at the same time, until you are left with just a nice end... Needs good timing, but the end result is nice, no mushroom head of melted paracord.
Marion
I like to pull the core out about 0.25" trim it off then pull the core back in. Then I melt the end. This keeps the core from coming out through the end of the cord.
Ric
