If you want a plugged connection between motor to VFD, a NEMA15-20L connector is suggested. Its "twist-lock" style. 4 conductors, 3 poles with ground. 20amp capacity.
The VFD to supply receptacle will depend on the amperage of circuit your electrician is installing.
Make sure you use a VFD with this motor. Hopefully you already know this, but 3PH does not plug into 220. Also, use the wiring diagram for low voltage. You could run this motor from a 120V outlet at 12 amps, into your VFD which will convert it to 3PH 208. You don't really need a dedicated 220V outlet for it, but it doesn't hurt. Just make sure you have the right VFD.
