- Dec 18, 2009
I am working on my second knife and all I have to harden the cutting edge is a cutting torch. I have access to a forge also. Those are my resources for heat. My blade when I went to harden the cutting edge today warped badly. I tried heating it back up and making it bend the other way a little to undo the warp but it did not work. Then I tried it again with making it bend the other way even further, it did get better but it is still warped. The blade is very thin and fairly long. It is 1095 and 01 Damascus folded 1584 times.
With it being so thin I do not think I would have enough metal left to remove more forge scale or hammer marks and I would be back to square one having to harden it again.
Maybe smash it between two bigger pieces of steel after it is heated leaving it clamped together until it cools? Hardening would be fubar then?
Or just deal with it...
The black area is worst part of the warp, sanded over it with sand paper wrapped around a file and that is the spot that the paper did not touch.
Thanks in advance.
Ronnie
Thanks in advance.
Ronnie
