Hey Guys....
I like to carry my big blades in a Concealex/Kydex sheath, high ride,, and I'll tell you why...
Keep in mind this is my own personal opinion...
With any large knife,, if the knife isn't in a fairly stiff sheath,,with a stiff belt loop you will get bounce and flop when you walk..
to stop this from happening,, you have to use a leg tie or thong..
This even gets worse when you have a drop leg sheath with a rather tight fitting or friction fitting sheath.. The knife can't be drawn with one hand unless a leg thong is used, or the sheath rides up as the knife is drawn...
With a high ride Concealex sheath that is tight on the belt, and tight to the body,, it does take a little getting use to,, however, I believe the ease of draw, and the fact that it is tight to the body, and snags on things less are a bonus.
When backpacking it can become a little bit of a problem, especially if you need frequent access to the knife, however this can be solved by strapping it down....
I use to carry drop legs way back when,, but found the leg thong to cumbersome, always came undone and it irritated my leg something Bad!!
Anyway,, just my opinion..
ttyle
Eric
O/ST
