Ed, I'd venture a guess that at least 85% of blades in new knives need to be crinked at the factory, and that includes single blade knives. There are too many variables involved with cutlery and assembly for a run of knives to have perfectly centered blades right off the bench. First and foremost is the fact that blade holes are drilled a couple of sizes larger than the pins to facilitate pin spread when the pin is hammered. If the blade hole were the same size as the pin, you'd wind up with a knife that you can't open or close smoothly because the pin is bound up in the hole. Due to this size difference you'll invariably have the pin compress more to one side than the other on most occasions, which will throw the blade just a tad. Slackening the blade after hammering in order to achieve smooth walk and talk will also throw the blade a bit. Additionally, it's extremely difficult to grind both sides of every blade dead center in a production environment, the cams on the mark and pile side grinders just don't work that way; the pile side always cuts a bit more near the tip in order to maintain an even edge. Couple that with the need to constantly adjust the depth of cut due to the grinding wheel steadily wearing down after each blade is ground.
Crinking is simply another step in the cutlering of a knife, and it's a required step at that. It's not that you're moving the blade over a half inch, most times it's just a tad, maybe a sixteenth or thirty second of an inch at the tip, which is generally imperceptible once the knife is finished.
Eric
