.... in a matter of minutes, not hours.
No disrespect intended, but every time I see this phrase posted I immediately wonder where anyone would get the notion that any knife would take hours to sharpen ...
The Worksharp Ken Onion edition, with its Blade Grinding Attachment, does a great job on all my edged tools: chef's knives, hunting/outdoor knives, and folding pocket knives, including my Sebenza. I like that I can create a very good edge on any knife, no matter what its starting condition, in a matter of minutes, not hours.
Initial re-profiling of a blade (using a coarse abrasive belt) demands very careful attention, of course, to avoid removing too much steel. After that, refining the convex edge -- and maintaining the convex edge -- is quick and easy, using just extra-fine abrasive belts, and/or a leather strop belt loaded with honing compound.
Here's the edge I put on my Sebenza:
The edge looks burnt?
... There is no supporting platen so dull belts on this implement lead to highly convexed edges on high-end steels.
Can you explain the mechanism here? Why would worn-out belts create a different edge geometry from fresh belts?
Dull belts have a harder time abrading the metal ...
I don't see how one could burn a blade using this tool. Hand-holding the blade against the belt, the temperature of the steel is always obvious. I expect one would drop the blade in pain long before it got anywhere near hot enough to burn. In my use of the tool, the blade edge never gets beyond warm.
@Cyrano: where can i find such a polarizer ?
Apparently it it pretty easy. The temperature you feel is a minuscule fraction of what occurs at the high surface area regions (apex and tip).
Many before you have impacted heat treat with powered systems and many of them had quite a bit of confidence. ...
Fascinating!
How do experts (like custom makers) manage this liability? Isn't edge sharpening typically done by hand, on a belt sander, as one of the final operations in making a knife?
And for non-experts like me: is there any measurement/inspection/test technology which can be used at home to address this concern?
