- Oct 8, 1998
After you melt it, obviously...
How do you apply it?
Marion
Marion
Why do you want to go through all that process? Pain in the butt for little gain, if any. Are you trying to water proof? You can do a good job of that with mink oil. Don't really need to do that even. You can harden a sheath by getting it really wet and putting in a home dehydrator. For most applictions, just dye and set in warm area. Finish with a product like TanKote or BagKote form Tandy.
Yeah, I am planning on using beeswax, I will melt it in a bain marie or double boiler.
Then I think I will pour it on with a spoon or little cup I guess. It's container would not allow for dipping.
I am gonna use a heat gun after it is applied, to get it to soak in, but applying seemed a bit of a problem.
I don't know that I have it licked, but then again, it may not taste good.
M
I simply heat the wax until it is just liquid, then immerse the sheath in the wax and let it soak up the wax. The leather needs to become warm to properly soak up the wax, but don't get the wax or sheath too hot or it will cook the leather and make it wrinkle and distort. If the wax wants to solidify on the surface of the sheath right away, the leather is too cool.
Remove the sheath, drain excess wax, and insert the knife into the sheath, and using the fingers (work rapidly!) mold the sheath to the knife. Withdraw the knife, wipe it off, and reinsert.
Rub the exterior of the sheath down with a soft cloth removing all excess wax.
Set the sheathed knife aside and let it cool off.
The knife should be well fitted to the sheath. Extracting the sheath might be a little difficult, but once it has been removed, the fit should be perfect. The sheath will be quite stiff, water proof, and retention will be very good.
Andy
So, with that method, I would be killing two birds with one stone, wax forming and waxing.
I may have to try that.
Marion
