Plenty of manufacturers have frame locks with a scale outside the frame.With respect, ti frame locks don't have 'scales on both sides' as you put it. Can't make a lock bar out of CF or G10.
I think you are referring to liner locks, as opposed to frame locks, AKA Reeve Integral Lock.
In fairness, he may be referring to bolster locks (Liong Mah Eraser), overlays (Reate Wave, ZT 0393), or other gray area takes.
If I had the money, I would buy it.But I bought a discontinued BM PRESIDIO yesterday.Been wanting one of the old Presidio for a while.Have not used 154CM in a long time.I bought the BM BARRAGE with m390 and I shaved my face with it.lol.So will see.Not sure if 154cm will get that sharp.Great knife, very good looking, good blade shape, steel and ergonomics.
One fatal flaw for me though, a deep carry clip that can't be replaced with a normal one.
Which is the only reason mine is for sale right now.
That was the other knife I was looking at. I love me some M4.The Spyderco Gale Bradley 2 is a much nicer knife, in my opinion. CF scales on both sides, a nicer aesthetic design... In comparison, the ZT just looks thrown together with good parts, but not really designed, the way the Spyderco is.
Look at the lines on it. It's just sexy. Looks comfy to hold. (still too big for EDC, but you're into "pocket swords" it seems, hehehe)
That looks awesome.I love that used look.The 0562 is one of my favorite knives. As others have said, the "thumb studs" are stop pins. ZT specifically made them round/domed so that people don't try to use them as thumb studs.
The problem with knives that are thumb stub and flippers is that the detent can't be dialed in for both. The optimal amount of force required for the detent is different when using different opening methods.
I like the design of the external stop pin located on the blade itself. Once the knife is locked open, the fact that the stop pins are on both sides of the blade means that there is resistance to lateral forces, such as when prying. I know that knives aren't for prying, and I always carry a multitool with me so I never use my knives that way, but if you need to, it's there. Hinderer and Strider both use this design. And if look closely, you'll notice that the G10 or CF show scale are cut so that they are slightly recessed at the point where the stop pin hits so that it contacts the steel liner. Good design all around.
It's called a slicer grind because that's what Hinderer calls the style. Its slicier than the Spanto that the XM-18 originally came with.
I've spine wacked my knife pretty hard, and it won't close. If I really needed to keep it locked down, I can induce a little bit of lock stick by pushing the lockbar further in from about 30% normally to about 50% lockup. At that point, it will stick, and it's definitely not going to fail a spine wack test.
I like tinkering with my knives, and I recommend using teflon/painters tape. Wrap it on, maybe 5 times around or so, and you're good to go. Just make sure you wrap it in a way that it doesn't unspool when screwing the pivot in. I'm too impatient to wait for the loctite to cure.
And I heard this thread needed pics... here's my modified 0562CF. If you like modifying, this is a great one to do it on.
