- Jul 10, 2002
here are some pics of the knife i made with the purpleheart handle.
http://picasaweb.google.com/terry.dodson/PurpleHeartKnife#
The blade was made from a 2 foot diamater sawblade that was 3/16" thick. I cut it out with an angle grinder. The handle is made from Purpleheart wood with vulcanised black spacing material between the handle and the steel. It also has home made mosaic pins in the handle, they are aluminum tube with black epoxy between the tube and a brass square tube inside it that is also filled with black epoxy. The wood has a super glue finish and then buffed on a buffer. The blade is slightly hollow ground to help with weight and make it sharper. The balance point is about where the guard is.
Edit: I did heat the wood to 300 degrees in an oven for half an hour before i cut and shaped it. Next time i think i will go with 350 degrees, it is supposed to make the purple darker.
