- Mar 8, 2008
The degree of flatness of basically any polished granite tile (in my experience so far) will be close enough. If you really need more flatness than that you probably should be using diamond stones in a high-precision jig arrangement 'cause all the flatness in the world won't mean anything if you aren't getting consistent strokes on it. Even microtome blades don't actually need that level of precision.Again, being a bit anal, but I wouldn't trust that a spare piece of granite is going to be perfectly flat. I've had pieces of marble that weren't particularly close, for example.
The hardness of granite compared to other stones means that much of the finishing process is done with a focus on precision to minimize wastage and its slow rate of wear also lessens the severity of any variances in spot pressure or time during polishing. Tiles are generally made from slabs that were already polished via an arduous automated process and simply cut into smaller pieces from there. Bonded abrasives, by their nature, wear to expose fresh grit. In the process of doing so, the uneven wear pattern pretty quickly results in deviations greater than that typically exhibited in most granite plates. If you're really worried about it, take a steel straightedge with ya' to the home improvement store. Personally I bought mine sight unseen off the internet and it's dead flat.
