That's good for general sharpening.I just hold the knife in one hand and the rod in the other
The advantage of the bench stone for reprofiling is one can get some downward pressure on the blade and that speeds things up.I do need to get an xtra coarse diamond stone.
Keep in mind that if you are trying to whittle your hair while it is still attatched (arm or beard) that going root toward the tip is more difficult than holding a hair n hand and dragging it across the edge while held by the tip. Check out a micrograph of a hair and you will see the "scales".For some reason my hair is very difficult to whittle whereas if I borrow a hair off a friend it whittles fine.
PS: I wouldn't call the Sharpmaker rods crappy; they are really useful.
If your hair is super fine that can be more difficult to whittle. My hair cutter has such fine arm hair she can't really whittle it with one of my edges which whittles my arm hair easily.
Thumbnail test: When lightly and CAREFULLY cutting the blade into the top of your thumbnail, does it "stick"? If it slides, it's probably not as sharp as it could be. Though some super polished blades will slide with this test.
