- Sep 5, 2017
My gec 78 feels gritty when I open it what's the fix?
This has worked for me for better than 50 years. I put a drop or two of mineral oil on the pivot and blade, use a toothpick to dig out the crud and it goes back in the pocket.just keep the lint dug out of the corners and put a little oil on it once in a while you will get by
^^^^ This right here. Just make sure you get it dry when done, drop of mineral oil in the pivot and spread some onto the blades and backsprings, wipe off excess.The standard answer begins with wash out with dawn dish soap and really hot tap water. Brush if needed, open and close blade. Then it starts to vary, some go the WD-40 or other cleaner/lubricant to ferret out the water, some just pressure dry with air. Then you either lube with something. 3 n 1, CLR, etc. Good surface wipe. If it going to cut apples at lunch then only mineral oil is favored.
Not for routine maintenance, but I've done that when I'm trying to free up an old knife with rusted springs and liners.I see that no one lets their knife soak overnight in a container of their favorite lubricants.
Hmmmm, food for thought.
