Hengelo_77
Basic Member
- Mar 2, 2006
by weight
check the ratio. The kind I use is 1:1 in volume but 4:5 in weight
I would think the increased volume is a non issue. Epoxy cures faster when warm, and the hardening process actually produces heat - a large volume will not cool off so easy, actually get warmer, and cure faster - does that make sense?Hi @CushingH. Since you authored a recent epoxy mega thread (highly recommended and very sciency) maybe you would know if the very large volume of JB Weld the OP is using in a drilled tang hole (as opposed to a slot) requires additional cure time? He can easily mock up a test for this. His hole is likely in the 1/2" range unless the tang stick is tiny. I recently drilled pith out of an antler and replaced with a slotted dowel as recommended by others here, greatly reducing the volume of epoxy needed.
Another thing not to do, is don't put acetone in a plastic cup. When you pick it up, you get the sides, but the bottom stays down and all the acetone runs out.
Most epoxy's come with a data sheet and give you min/max temperatures for curing too. It helps a ton to follow what they say. One bar top self levelling epoxy I used said minimum temp of 78 degrees. On the forum part of their website there was a thread that showed example after example after example of fails when customers didn't follow the temperature instructions.Kbright, don't let epoxy cure in the cold. Epoxy+cold=bad m'kay
I always take whatever I'm epoxying in to the house to harden in a warm room.
That helps, but I would still be very cautious about the approach.I was not heating with an open flame, and it was just hot enough to cause it to start to condensate on the cold blade. It was just done as a test to see about building a dedicated set up.
Go to the local feed store and get two plastic syringes. Fill them with part A and part B and put a piece of masking tape on each one with the A and B written on the tape with a pen. Squirt out the required amount of each in a non-waxed cup and mix. Leave the unused epoxy in the syringes. When the epoxy is used up, clean the syringes with acetone and refill with epoxy.
