How do you sharpen S30V?
Anyone have any recommendations on sharpening techniques for S30V?
If you use a 2" x 72" belt, what grit (eg. 120 grit?) and steps do you use? Do you power strop with a buffer? Do you use polishing compounds?
Does S30V like a rough edge or a finely polished one?
I will be sharpening a 7" Santoku, convex edge.
Thanks!
I use 3M Trizact belts up to A-30 (400? grit), then green CrO rouge on a buffing wheel. S30V likes polished edges.
I use a 400 grit aluminum oxide belt (make sure it is a fresh 400 grit belt) at approx. 17 deg. each side, and then on to a leather strop with white buffing compound. It comes out hair poppin sharp every time.
Paul
www.savageknives.ca
savageknives@golden.net
For a convex ground blade like above, grind on a slack belt. The structured abrasives like the 3M Trizact and Norton Norzon belts run cooler and last much longer than AlO belts.
