How do YOU sharpen your Beckers?
50 degrees inclusive, or on the Lansky, 25. I find its good blend of thickness and angle to render a good working edge.
Moose
WOW!
I just used the smart protractor app on my Droid to figure out what 25 degrees looks like freehanding on my ezelap and it made a huge difference!
Edit to add: Just tried it on my BK11 which I was having trouble with, and it worked. I must have been freehanding at about 15 degrees.
Never used a strop before... Its that just to remove the microburrs?
I use Spyderco ceramic stones and finish them off with a strop loaded with Flexcut gold compound.
WOW!
Glad its working for you.
Strop removes the burs and polishes the edge to make finer micro serrations along the edge. A polished edge tends to last longer, as it lessens the friction along the edge length, and removes less metal when passing through the media you're cutting. "Toothier" edges have a better slice when pulled or pushed, but tend to dull out faster, because more metal is left rough and is removed when cutting media.
Moose
Spyderco medium/fine pocket hone. If I am sharpening the 14 I just do regular back and forth strokes. To sharpen the 9 I do circles.
kg4ghn, I've got one of those Spyderco stones as well. They are extremely handy. I find myself sharpening with that stone more than my larger Spyderco stones. I generally use the stone as if it were a file, keeping the blade still in one hand while I drag the stone across the edge. I have more control that way, and its been working great for me.
I use a combination of Norton India stone / Bark River [black,green,white] compound with leather strop / ceramic sticks / Japanese water stones / Lansky ceramics / and sometimes a Hunter Honer / 400 through 2000 grit sandpaper with mousepad / Fallkniven DC4 (excellent field or just regular use tool) / Chevy truck window / sheesh.... I'm trying a bit of it all and for me the most difficult has been getting my BK11 [edc as necker] in order / finally got it and one of the Train Wreckers convexed / leaving the other BK2's and BK9 with factory grind edges.... just a work in progress... who knows where it all ends, if ever....
Started back in the day with a whetstone. Moved to a ceramic rod and then stayed with that for quite some time. Then recently a fiasco with a Lansky sharpening system thingy put me right back to hand sharpening with the ceramic rod. For the convex goodness, I free hand with assorted nail files/buffers, and I don't think I will be going back to a sharpening system any time soon. Once I get a belt grinder then I might use that, but for now, I am doing fine with what I have.
