:snip: I wonder how I could get those magnetic strips....cover them with some sort of material and then I could attach the knives magnetically on the wall.
I am liking that idea a lot......:snip:
Amazon has quite a few options; even one covered in Bamboo...
Link.
IIRC the one I have in my kitchen is made by Chicago Cutlery and it holds very well. The key is making sure it is strong so it works through fabric. I know the standard magnetic knife strips vary dramatically in quality, so be forwarned if you can't try before you buy. As for the thin fabric; it can usually be found anywhere they sell craft supplies, same goes for materials for the frame.
Better yet, you could just make your own by getting some disc shaped rare-earth magnets and mounting them in a board. You could create whatever shape and size board you wanted and drill holes just deep enough for the magnets to be glued in and sit just above flush with the surface. Then cover the board with the material of your choice, I'm thinking something like the thin felt used on a pool table, and make a picture frame to complete the display board.
Rare earth, or neodymium, magnets are strong as hell and should have no problem holding the weight of a pocket knife through thin fabric. Hell; if the magnet is thick enough, I bet you could wrap it in thin leather or suede and it would still hold.
Materials are easy:
- 3/4" (or thicker) plywood or board cut to whatever size you want.
- Disc-shaped neodymium magnets... These should do nicely.
As you can see there are several sizes and thicknesses depending on how much weight you want to hold and what pattern you want to use.
- A few square feet of the fabric of your choice.
- A pre-made picture frame with the board cut to the same dimensions, or make your own frame to fit your board.
A miter box and some fancy base-board works quite well for making a cheap frame.
- The appropriate hardware/glue to build your frame and tack the fabric to the back of the board.
- A few basic handtools. (Hand drill, hammer, cheapo miter box from Wally World, and some sand paper and/or spray paint/stain to finish the frame.)
It can be as simple or fancy as you choose. The magnets can be placed only in certain spots or in a checker pattern all over so you can place the knives almost anywhere on the board. It'd be like a table on the wall.
The only two things I'd say to be careful of is to make sure you use thick enough magnets for your particular knives, and be sure they sit just above the surface of the board so they touch the knife. If you accidentally drill too deep, just put a washer in the hole to bring the magnet up to the proper height. Quarter inch thick neodymium magnets are probably overkill, but you don't want a knife to fall off the board and skewer someone, or worse, break the tip.
